Purduephotog
Mar 09, 2019Guide
M4300 LACP/LAGG only works when incorrectly configured
I have video proof this time, although I'm not sure if I can post it.
I had a misconfigured M4300 where one of the hosts had a VHID that overlapped the LACP ports. The LAGG functioned correctly...
Purduephotog
Mar 13, 2019Guide
(The inactive port is weird as it was working fine until this pull)
Anyone in tech?
Having cleaned out everything, can tech support provide a working LACP example script?
*************** show port status all ***************
Media STP Physical Physical Link Loop Partner Flow
Intf Type Mode Mode Status Status Status Control
1/0/1 DAC DIS 10G Full 10G Full Up NA
1/0/2 DAC DIS 10G Full 10G Full Up NA
1/0/3 DAC DIS 10G Full 10G Full Up NA
1/0/4 DAC FWD 10G Full 10G Full Up NA
1/0/5 DAC DIS 10G Full 10G Full Up NA
1/0/6 DAC DIS 10G Full 10G Full Up NA
1/0/7 DAC DIS 10G Full 10G Full Up NA
1/0/8 DAC DIS 10G Full 10G Full Up NA
1/0/9 DAC FWD 10G Full 10G Full Up NA
1/0/10 DIS 10G Full Down NA
1/0/11 DIS 10G Full Down NA
1/0/12 DIS 10G Full Down NA
1/0/13 DAC FWD 10G Full 10G Full Up NA
1/0/14 DAC FWD 10G Full 10G Full Up NA
1/0/15 DAC FWD 10G Full 10G Full Up NA
1/0/16 DAC FWD 10G Full 10G Full Up NA
1/0/17 DAC DIS 10G Full 10G Full Up NA
1/0/18 DAC DIS 10G Full 10G Full Up NA
1/0/19 DAC DIS 10G Full 10G Full Up NA
1/0/20 DAC DIS 10G Full 10G Full Up NA
1/0/21 DIS 10G Full Down NA
1/0/22 DIS 10G Full Down NA
1/0/23 DIS 10G Full Down NA
1/0/24 DAC FWD 10G Full 10G Full Up NA
*************** show port-channel all ***************
Log. Channel Admin Mbr Device/ Port Port
Intf Name Min Link Mode Type Ports Timeout Speed Active
lag 1 NAS15x50 1 Up En. Dyn. 1/0/1 actor/long 10G Full True
partner/long
1/0/2 actor/long 10G Full True
partner/long
1/0/3 actor/long 10G Full True
partner/long
1/0/4 actor/long 10G Full False
partner/long
lag 2 NAS16x51 1 Up En. Dyn. 1/0/5 actor/long 10G Full True
partner/long
1/0/6 actor/long 10G Full True
partner/long
1/0/7 actor/long 10G Full True
partner/long
1/0/8 actor/long 10G Full True
partner/long
lag 3 NAS11x60 1 Up En. Dyn. 1/0/17 actor/long 10G Full True
partner/long
1/0/18 actor/long 10G Full True
partner/long
1/0/19 actor/long 10G Full True
partner/long
1/0/20 actor/long 10G Full True
partner/long
