sstubblefield8's avatar
Aug 10, 2021
WAX610 set management vlan incorrectly
I was trying to configure a bundle of WAX610's and on the IP/Lan page, I set the access VLAN correctly but specified the wrong management VLAN. I've tried setting my managed network switch to the correct management VLAN, but they aren't connecting to the web interface. My network scanner sees them over the switch, but it just won't load the interface.
These waps are already installed, and not exactly accessible. Is there any way to get to them without doing a factory reset?
  • sstubblefield8,
    Welcome to the community! :)
    There is no other way but to reset the WAX610 access points to factory default settings.
    DaneA
    NETGEAR Community Team
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    sstubblefield8,
    DaneA
ProSupport for Business
