Purduephotog
Mar 09, 2019Guide
M4300 LACP/LAGG only works when incorrectly configured
 I have video proof this time, although I'm not sure if I can post it.
 I had a misconfigured M4300 where one of the hosts had a VHID that overlapped the LACP ports. The LAGG functioned correctly...
schumaku
Mar 14, 2019Guru - Experienced User
So the LACP bonding of the four single interfaces is done on the card, or on the Linux Kernel bonding driver?
If it's Linux bonding, check e.g.
# cat /proc/net/bonding/bond0
Purduephotog
Mar 15, 2019Guide
I'll check that first thing Monday morning.
In the meantime, I have a video uploading. I had to redact portions of it.
https://www.youtube.com/watch?v=NuUF2Rkailo
I'm not a video guy so I have no idea how to enlarge portions of it to show you better, but at HD you should be able to watch the speed suddenly increase once I uncheck the ports associated with the LAG membership, and then decrease when I add the ports back in.
