cerhorn's avatar
cerhorn
Tutor
Dec 18, 2016
Recommend replacement for FVS318
I just upgraded to a DOCSIS 3.0 Modem, and upgraded my internet service with Crapcast.  My FVS318 gives me about 11 Mbps download, while a direct connection from computer to the modem gives me 90 Mbp...
  • DaneA's avatar
    Dec 19, 2016
    Hi cerhorn,
    Welcome to the community! :)
    The FVS318 have a LAN-to-WAN throughput of just 11Mbps.  You will need to have a firewall that has a LAN-to-WAN throughput greater than 90Mbps.  I recommend you either of the following: FVS318Gv2, FVS318N, FVS336Gv3 or SRX5308.  Kindly access the data sheet below for you to check their specifications and comparison:
    ProSAFE® VPN Firewall Series Data Sheet
    DaneA
    NETGEAR Community Team
ProSupport for Business
