HolzbauerSNK
Aug 08, 2018Aspirant
Restart of Switch
Hello,
my company use M4300-52G ProSAFE 48-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+ switches. I have now following issue or question.
One of our switches has an uptime from 273 d...
JohnC_V
Aug 09, 2018NETGEAR Employee Retired
Hi HolzbauerSN,
Welcome to our community! :)
Maybe it did restart the switch automatically. May you be able to check the logs so that we may know what seems to be causing that issue?
HolzbauerSNK
Aug 13, 2018Aspirant
Sure i will load up the log. I already read it but don't really understand the issues.
Thanks
- JohnC_VAug 13, 2018NETGEAR Employee Retired
Thanks! I found out that it did restart once due to inconsistent state also it did fails to read conflicting ARP packet from stack before the reboot. It didn't say anything much the cause of the reboot. If you have a loop, you can disconnect it first and then monitor.
