COP_IT
Nov 20, 2019Aspirant
Routing Mode/DHCP
Dumb question here sorry, Routing mode should only be enabled on the Core switch correct, all other switches dont require it if i have DHCP helper enabled for every VLAN to each switch. Second dumb ...
- Nov 21, 2019
Hi COP_IT,
Let me share the article below.
This article describes how to configure routing VLANs on a NETGEAR managed switch with shared access to the internet.
You can use this example extension to configure non-core switches.
But there are a lot of details that you need to consider, such as network access restrictions between departments or whether each department is allowed to access the Internet....etc
I hope that will be helpful.
Thank you
COP_IT
Nov 21, 2019Aspirant
Lots of questions sorry, trying to make a better network than what is currenly here. From Core switch should the ports be configured for the Specific VLAN, default vlan 1, another vlan 10, should the ports be configured Untagged for the default vlan or the VLAN ID for the network. Example Department 1 is 10, department 2 is 20, department 3 is 30, should i untagg those ports on the core switch that go to that network. Or should i setup the default vlan ID for all the switches as untagged on the core switch and then just tagg the vlan ID per network.
kevin_hong
Nov 21, 2019Apprentice
Hi COP_IT,
Thank you
