Piotr_Gronowski
Aug 07, 2018Aspirant
routing vlan's ona Managed switch GSM4328PS
GSM4328PS - - GSM4328PS - - I created vlan 1212, 1200 and 1250. I set ip addresses for vlans . vlan 1200 has ip 192.168.110.251, vlan 1212 has ip 192.168.112.251. I add routing between vlan 1200 and ...
JohnC_V
Aug 08, 2018NETGEAR Employee Retired
Hi Piotr_Gronowski,
Welcome to our community! :)
It seems that you were having issues with the VLAN routing on this managed switch. May I know if you added a default route to the VLAN routing page? Please add a default route by using an IP that is not currently used as one of your VLAN GW. You can use the IP address of your router.
You may refer to this article.
Piotr_Gronowski
Aug 09, 2018Aspirant
Hi John.
I added a default route to my internet router. Please luke at my startup config. Hosts from vlan 1200 ( 192.168.110.x) have access to internet too. I upgraded tthe switch to a newes firmware, but it didn't solve my problem.
regards
Piotr Gronowski
- JohnC_VAug 09, 2018NETGEAR Employee Retired
You may need to add the default route in the switch and not in your router.
- Piotr_GronowskiAug 09, 2018AspirantI did it. Nad nothing. Host from vlan 1200 have access to internet. Hosts from vlan 1212 haven't.
- Piotr_GronowskiAug 09, 2018AspirantI did it. Nad nothing. Host from vlan 1200 have access to internet. Hosts from vlan 1212 haven't. I think that problem od in a port's configuration .please plik at an attachment .Port 1/0/4 is in an access mode .why is a trunk on this port?
