OperatorITSP's avatar
OperatorITSP
RSPAN to vmware not working
Hello
We have a stack of two M4300s. I want to span two LAG ports to RSPAN vlan and monitor this on destination on vmware distributed switch.
I followed following video to set up vmware part.
https://www.youtube.com/watch?v=-VanRFpeUSI
Relevant netgear config is below.
vlan name 1514 "RSPAN"
vlan 1514
remote-span
port-channel name lag 1 FW01
interface 1/0/1
addport lag 1
exit
interface 2/0/1
addport lag 1
exit
port-channel name lag 2 FW02
interface 1/0/2
addport lag 2
exit
interface 2/0/2
addport lag 2
exit
interface 1/0/31
description 'ESX'
vlan participation include 1100-1101,1103-1104,1113-1114,1254,1514
vlan tagging 1,1100-1101,1103-1104,1113-1114,1254,1514
exit
interface 2/0/31
description 'ESX'
exit
monitor session 1 destination remote vlan 1514 reflector-port 1/0/48
monitor session 1 source interface lag 1
monitor session 1 source interface lag 2
monitor session 1 mode
My issue is that I see no traffic on vlan 1514 on vmware distributed switch. When select other vlans as source under vmware distributed switch, I do see traffic so this points me to some issue between netgear and vmware.
We use similar netgear setup on other M4300 stack, but destination is physical port and this is working fine.
Any idea what can this be and how to fix this?
Many Thanks.
  • schumaku's avatar
    schumaku
    No fix possible - this is very likely a imitation. A mirror port can't be a LAG.
    • OperatorITSP's avatar
      OperatorITSP
      Hello
      On our other stack we have following working ok. Only difference is that destination is not RSPAN vlan, but physical port.
      port-channel name lag 1 TO-FW01
      interface 1/0/1
      addport lag 1
      exit
      interface 2/0/1
      addport lag 1
      exit
      port-channel name lag 2 TO-FW02
      interface 1/0/2
      addport lag 2
      exit
      interface 2/0/2
      addport lag 2
      exit
      monitor session 1 destination interface 2/0/48
      I changed config on problematic stack to following(to get some traffic from physical ports not LAG) and it's still not sending traffic to VLAN 1514.
      vlan 1514
      remote-span
      monitor session 1 source interface 1/0/25
      monitor session 1 source interface 2/0/25
ProSupport for Business
