ofuen's avatar
ofuen
Searching for an LOV for netgear switch GSM7224V2/GSM7224-200
I need a letter of volatility for netgear switch MODEL GSM7224V2 AND GSM7224-200 L2 managed switch. Needed for removal from secure area for repairs. If LOV is same for all GSM7224 models then one LOV stating for all models will suffice.
  • Hi ofuen,
    The GSM7224-200 is the product order code for GSM7224v2 (v = version) and can be classified as the following:
    GSM7224-200NAS - product order code of GSM7224v2 switch in North America
    GSM7224-200EUS  - product order code of GSM7224v2 switch in Europe
    GSM7224-200AJS - product order code of GSM7224v2 switch in Asia
    Kindly download the Letter of Volatility of the GMS7224v2 switch on this link.  The link will expire within 2-3 days.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi ofuen,
    DaneA
    • ofuen's avatar
      ofuen
      Thank you for the quick response and information. Orlando
ProSupport for Business
