JSXT's avatar
JSXT
Service Management Interface M4300, Stacking Modus
We have build  a stack of 4 x M4300 12x-12f.
The Stack should be only managed by the Out-of Band Service Interface (backsite).
Build as stack, there is only one configuration option for that interface, despite there are 4 physical Interfaces (one for each switch).
It's not made clear in the manual  which one ist the interface we could use to mangage the switch-stack (try and error works), but the real question is:
What will  happen when one switch (that hold the Out of Band Management interface) goes down?
There's no tutorial to configure the standby behavior, should we connect all management interfaces to our management network?
What about the IP addresses of the 4 OOB Interfaces.
Need some clearance here.
Thx
1 Reply
ProSupport for Business
