DerDoubleD
Aug 25, 2022Follower
Setup/Change Management VLAN ID for GS308E
Hello, where can I set the Mannagemant VLAN ID on Netgear GS308E? The Switch has the latest firmware. Thanks in advance Best regards Daniel
schumaku
Aug 26, 2022Guru - Experienced User
Almost a classic - Netgear should post KB entry on these questions.
Like (almost, with a few exceptions only) all Plus GSxxxxE[n][n] switches, there is no managed core, and no management VLAN, never was. Management access is indeed possible from any VLAN, _and_ on untagged connections only, and in case there is IP access configured only for that specific IP (again on any untagged) connection configured to any VLAN. Tagged connections ie. over a trunk don't allow any management access.
-Kurt
