Anto0506
Sep 29, 2022Aspirant
SFP+ 10 Gig managed network switch
hi looking to source a 3GB -10 GB SFP+ network switch, have a minimum of 4 eth ports. Need the unit to be as compact as possible as it will be housed in a confined space Also looking to Source SFP ...
DaneA
Sep 29, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Since you are looking for a compact fully managed switch, you may want to consider the M4300-8X8F switch model. It has 8x10GBASE-X SFP+ ports and 8x10GBASE-T ports. Its dimensions are as follows:
Width: 8.35 inches (21.2 cm) (half-width);
Height: 1U - 1.73 inches (4.4 cm);
Depth: 13.58 inches (34.5 cm)
To know more about its specifications as well as the compatible SFP+ modules for the M4300-8X8F switch, kindly check the M4300 data sheet here.
Furthermore, NETGEAR has a vast variety of NETGEAR Business Switch Models. Kindly check other business switch models that might fit your network requirements on the link below:
DaneA
NETGEAR Community Team
- Anto0506Sep 30, 2022Aspirant
Hi
Thank you for coming back to me
The model suggested is too large
I also looked at ms510txup.
Please note that I need to house this switch in a Subsea bottle. Please see attached pics
Available power supply in the bottle are 5Vdc ,12Vdc,24Vdc or 48VDC
Also the switch can be mounted directly to support plate in bottle. Can we save space without the plastic enclosure.
Size limitation are as such length 250mm
Its height and depth would need to be accommodated into a circular space 153mm in diameter including RJ45 connections (Please see attached pics)
Also note that anything from 4 to 8 Lan ports would be fine
Also note that a SFP+ optical port would be preferable over and XFP port
Best Regards
Anthony
