grgdunn
Aug 19, 2016Aspirant
SFP fiber ports between a GS716Tv3 and GS748Tv4 and a GS110TP
Has anybody had any issues with the SFP ports not reconnecting after restarting their GS716Tv3 switches? I currently have 3 of these switches and have experienced this problem on two of them, one of ...
- Aug 27, 2016
It appears changing the patch cord worked, its hard to tell for sure as it's not convienent to restart the switch often. :)
JohnRo
Aug 22, 2016NETGEAR Employee Retired
Hello grgdunn,
Welcome to the community!
I have not seen such a case. What firmware versions are you using on the GS71Tv3's?
Thanks,
- grgdunnAug 22, 2016Aspirant
Hi,
Thanks for the reply, the firmaware is 6.3.1.11 but after further investigation I think the probelm is due to attenuation, this fiber installation is over 10 years old and to the best of my knowledge the patch cords have never been replace or cleaned, I will report back what I come up with after cleaning and/or replacing the patch cords.
Thanks again,
Greg
- JohnRoAug 22, 2016NETGEAR Employee Retired
Hi grgdunn,
Oh, that was old. :) We'll look forward to your update.
Thanks,
- JohnRoAug 26, 2016NETGEAR Employee Retired
Hi grgdunn,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- grgdunnAug 27, 2016Aspirant
