cabwav
Mar 13, 2016Tutor
sfp trunking
Hello I am new to managed switches and I would like some help with configuring two Netgear switches (GS716Tv3 and GS110TP). I am trying to configure a trunk link between these switches using two ...
- Mar 14, 2016
Hi cabwav,
I think that you will need to configure STP on both switches to prevent loops. I suggest that you configure RSTP on both GS716Tv3 and GS110TP.
DaneA
NETGEAR Community Team
DaneA
Mar 14, 2016NETGEAR Employee Retired
Hi cabwav,
DaneA
- cabwavMar 14, 2016Tutor
Hi DaneA
Awesome! That did it. The GS716 had RSTP as a default setting, but the GS110 had MSTP as a default. Thank you for your help, I never would have found this one by myself....
Kind regards,
cabwav
