cabwav
Mar 13, 2016Tutor
sfp trunking
Hello I am new to managed switches and I would like some help with configuring two Netgear switches (GS716Tv3 and GS110TP). I am trying to configure a trunk link between these switches using two ...
- Mar 14, 2016
Hi cabwav,
I think that you will need to configure STP on both switches to prevent loops. I suggest that you configure RSTP on both GS716Tv3 and GS110TP.
DaneA
NETGEAR Community Team
DaneA
Mar 14, 2016NETGEAR Employee Retired
Hi cabwav,
DaneA
cabwav
Mar 14, 2016Tutor
Hi DaneA
Awesome! That did it. The GS716 had RSTP as a default setting, but the GS110 had MSTP as a default. Thank you for your help, I never would have found this one by myself....
Kind regards,
cabwav
