tonynsx
Sep 02, 2021Luminary
SNMP email alert
I would like to setup email alerts on my switches. I don't have Insight. Is this possible with SNMP? I'm not too familiar with SNMP. These are the types of switches I'm using. I would like to se...
- Sep 03, 2021
Hello tonynsx
SNMP does not send email notifications for the obvious reasons on it's own.An SNMP management system is the "API" of choice for a lot of networking equipment. You can operate an SNMP-Trap receiver (the switch SNMP system requires one or multiple IP addresses configured), can poll whatever information available from a switch - and then of course this system can create and sent whatever kind of alerts, operational changes of interest, push messages, and much more. Build your own (for the sake of it in Python) SNMP system, or look into Open Source or commercial offerings. If one desperately want - create output by email.
Heavily polling a switch - by whatever method - can have an impact on the operations.
In my opinion, directly polling a Web UI by whatever programming the wrong way. SNMP is much more powerful for almost every purpose. Adding more APIs to switches will add load to a management core which is not intended to handle even more load.
Netgear started the support of a REST API for configuring, monitoring or troubleshooting for the M4300 Series as of firmware version 12.0.11.18. Details are available on demand (talk to OOM-9 or LaurentMa by PM) via a limited access section here on the community if you are interested.
-Kurt
