klam238
Mar 27, 2023Aspirant
SNMP MS510TXUP-100NAS
Hi, I have ordered a new switch MS510TXUP-100NAS. Is possible to query wattage / voltage / current used in EACH port with snmpget v2. I see this data displayed on the webpage UI but can't find a ...
klam238
Mar 28, 2023Aspirant
Ok, so it looks like GS510TLP has measuring capabilities because it supports NETGEAR-POWER-ETHERNET-MIB
However, MS510TXUP does not list NETGEAR-POWER-ETHERNET-MIB, so I'm concluding it's not possible to measure on the POE++ switch
Is that correct?
Is there a firmware upgrade or something that would get NETGEAR-POWER-ETHERNET-MIB to work on MS510TXUP?
schumaku
Mar 29, 2023Guru - Experienced User
Haven't spotted any updates or deployments of the fastPathpowerEthernetMIB for a longer time on newer products - would be nice to have of course:
NETGEAR-POWER-ETHERNET-MIB DEFINITIONS ::= BEGIN
-- Copyright Netgear Inc (2003-2015) All rights reserved.
-- This SNMP Management Information Specification
-- embodies Netgear Inc's confidential and proprietary
-- intellectual property. Netgear Inc retains all title
-- and ownership in the Specification including any revisions.
-- This Specification is supplied "AS IS", Netgear Inc
-- makes no warranty, either expressed or implied,
-- as to the use, operation, condition, or performance of the
-- Specification.
IMPORTS
MODULE-IDENTITY, OBJECT-TYPE, Integer32, Gauge32 FROM SNMPv2-SMI
TruthValue FROM SNMPv2-TC
ng700smartswitch FROM NETGEAR-REF-MIB
DisplayString FROM RFC1213-MIB
pethPsePortEntry, pethMainPseEntry FROM POWER-ETHERNET-MIB;
fastPathpowerEthernetMIB MODULE-IDENTITY
LAST-UPDATED "201803020000Z" -- 02 Mar 2018 12:00:00 GMT
ORGANIZATION "Netgear Inc"
CONTACT-INFO ""
