tahiti25
Jun 04, 2019Aspirant
Stacked switch stuck on boot up flashing amber/yellow led - M5300-52G3
dI have the following setup for a cctv solution and I am experiencing the issue described in the subject with switch 3 = Management Switch 1 - Netgear M5300-28GF3 Slave Switch 2 - Netgear M5300-...
DaneA
Jun 04, 2019NETGEAR Employee Retired
Hi tahiti25,
Kindly remove the 3rd switch from the stack and check if you can still access it via CLI. If ever CLI access is possible, kindly try to perform Xmodem. Kindly access the article below and use it as reference guide:
https://kb.netgear.com/21/What-do-I-do-when-my-FSM-managed-switch-does-not-boot-up
Otherwise, I advised you to open a chat or online support ticket with NETGEAR Support anytime and kindly state your concern. If ever the support expert declared that your 3rd switch from the stack is faulty, be ready to submit a .pdf or .doc copy of the Proof of Purchase or Sales Invoice of it for warranty verification. If the hardware warranty is still valid, an online replacement will follow.
DaneA
NETGEAR Community Team
