WojtekC
May 18, 2020Guide
Stacking cable replacement
I have some stacks built with M4300 switches. Stack connections are made using 10GBASE-T ports with ring topology. Each stack consists 3 units, 2x M4300-28G and 1x M4300-28G-PoE+. Recently I've found...
Retired_Member
May 20, 2020Hi WojtekC
Welcome to Community!
Yes, just as you said, Ring topology is redudent for Stacking port traffic. You can replace cable one by one, it will not interrupt normal service.
Hope it helps!
Eric
