JoelSpeed
Jun 08, 2015Aspirant
Stacking GSM7352S with GSM7328S - Problem!
I have two switches as in the title, a pair of AX742 modules and a cable linking them. Both switches are running firmware 8.0.3.49. I believe them to be compatible as stack members but cannot seem to...
RX
Jun 09, 2015Luminary
I believe there 2 stacking module bays on the GSM7328S and 4 stacking module bays on the GSM7352S. Have you tried using the other stacking module bays of both switches to isolate the problem?
Have you tried using other stacking cable?
Have you also tried to perform a factory reset on both switches then reconfigure it from scratch?
