JoelSpeed
Jun 08, 2015Aspirant
Stacking GSM7352S with GSM7328S - Problem!
I have two switches as in the title, a pair of AX742 modules and a cable linking them. Both switches are running firmware 8.0.3.49. I believe them to be compatible as stack members but cannot seem to...
JoelSpeed
Jun 09, 2015Aspirant
Hi thanks for the reply, I have tried moving the modules around to various locations but unfortunately to no avail.
I have factory reset one of the switches so far but not the other. I may be able to do this but will need to schedule the downtime as the switch is in production unfortunately
- JohnRoJul 27, 2015NETGEAR Employee Retired
Hi JoelSpeed,
We would like to know if you were able to test the switches.
I'll look foward to your update.
Thanks,
