JoelSpeed
Jun 08, 2015Aspirant
Stacking GSM7352S with GSM7328S - Problem!
I have two switches as in the title, a pair of AX742 modules and a cable linking them. Both switches are running firmware 8.0.3.49. I believe them to be compatible as stack members but cannot seem to...
JoelSpeed
Jun 09, 2015Aspirant
Hi thanks for the reply, I have tried moving the modules around to various locations but unfortunately to no avail.
I have factory reset one of the switches so far but not the other. I may be able to do this but will need to schedule the downtime as the switch is in production unfortunately
JohnRo
Jul 27, 2015NETGEAR Employee Retired
Hi JoelSpeed,
We would like to know if you were able to test the switches.
I'll look foward to your update.
Thanks,
