pingster400
Feb 22, 2021Aspirant
Static IP vs. IPv4 Network Interface
We purchased a few M5100-28G and M4100-50G switches a while ago, however we have an issue where even though you give the switch a static IP, the IPv4 Network Interface will still show up as 169.254.1...
JohnC_V
Feb 24, 2021NETGEAR Employee Retired
Welcome to our community! :)
You may change the management IP of both switches by going to System > Management > Management Interfaces > IPv4 Management VLAN Configuration. From there, you may set your specified IP address of the switch in order for you to access it.
John
NETGEAR Community Team
- pingster400Feb 24, 2021Aspirant
Thanks for your reply John, however this doesn't really solve the problem.
For example, one switch I have already configured using static IP 10.25.1.51/23 which works fine.
However after the switch rebooted, the IPv4 address reverted back to 169.254.100.100/16 with no DFGW.
Ironically I have just logged onto the switch via our Windows DC on network 10.25.1.0/23 using a web brower to access the gui via 10.25.1.51/23 and the switch login screen appears and I can see the switch working, although the IPv4 address is still 169.254.100.100/16 with no mention of 10.25.1.51/23.
On another note, on the 10.25.1.0/23 network if I gui to 169.254.100.100, then the switch login page still loads.
Any thoughts on why this would happen?
- JohnC_VFeb 26, 2021NETGEAR Employee Retired
You may need to save your configuration first before rebooting the switch so that it won't be deleted. You may save your configuration in Maintenance > Save Config > Save Configuration.
Your configuration changes are saved across a system reboot. All changes submitted since the previous save or system reboot are retained by the switch.
John
- pingster400Feb 26, 2021Aspirant
Hi John,
I should have mentioned that I save the running-config of the switch first so know that it's not an issue with a reboot and losing the saved config.
Switches in this condition have been installed for c. 3 years with a number of reboots. On a few occasions but not always, this only happened after the firmware was updated and it removed our static IP, and reverted to the default. However the switch was still fully useable using our static IP, you couldn't see it listed anywhere on the switch.
