doctohelp
Sep 30, 2015Aspirant
Switch block Ubuntu Access to Webinterface
Hello, i have a Log Entry: <14> Sep 30 11:59:05 192.168.202.247-1 UNKN[2173068724]: dtl_net.c(2177) 9 %% mac entry not found:0x0:0x15:0x5d:0xffffffca:0xffffffae:0x28 I can not ping the switch. ...
- Oct 08, 2015
I have found the solution, the latest firmware (06/2015)
Thank you for your help.
Mike
JohnRo
Sep 30, 2015NETGEAR Employee Retired
Hello doctohelp,
Welcome to the community!
I understand you are having some issues accessing your switches' web-UI using your ubuntu computer. For us to be able to help you with this, I would like to ask some questions which I have listed below:
1. Is the switch already configured with static IP or is it on DHCP?
2. Does the Ubuntu OS have the same IP of the switch?
3. What is the model number of the said switch?
You can also take a look at this article and see if it might be able to help you fix the issue.
We'll look forward to your response.
Thanks,
doctohelp
Oct 04, 2015Aspirant
Hello JohnRo,
Excuse was a few days sick.
STATIC
No, Ubuntu has 192.168.202.213/23 the Switch 192.168.202.247/23 i'm testing a another IP -> same
GS716Tv2
It does not even ping.
The same Problem have i whit a another Ubuntu.
- doctohelpOct 08, 2015Aspirant
Mike
- JohnRoOct 08, 2015NETGEAR Employee Retired
Hi doctohelp,
I am glad the issue was fixed with the latest firmware. If you need more assistance in the fiture we'll be happy to help.
Thanks,
- May 25, 2022Retired_Member
