MarkusKern
Nov 24, 2017Tutor
Switch freezes after some days working OK
After some days working correctly some of our several of our switches freeze. Is this a known behavor? What can I do to overcome the problem? I need the switches (GSM4328PS) accessable all time. The ...
Hopchen
Nov 24, 2017Prodigy
Hi MarkusKern
When did this begin? Did anyone make any changes before this started occurring?
What do you mean by "freeze"? Will the switch still pass traffic, but you cannot access the GUI? Or does the switch stop passing any traffic at all?
How do you "solve" it temporarily? Do you reboot and it then works again for a while?
Cheers
MarkusKern
Nov 24, 2017Tutor
Hi
Thanks for your reply. This behavior exists since we installed the switches. There are some which behave correctly and others with the problem mentioned. After powering off the devices and restarting them they behave correctly for some time.
- HopchenNov 24, 2017Prodigy
Thanks for clarification.
Can I ask that you upload the Tech Support file to this thread? It would be helpful to see it. We would need to see a tech support file from one of the problematic switches.
Please remove any passwords and serial numbers, from the file, before uploading.
Cheers
- MarkusKernNov 27, 2017Tutor
Good morning
On one of the switches I retrieved the tech support file from I installed the most recent firmware last Friday. This one was running normally this morning. The other one has beed rebooted last week and froze again in between. I appended the two text files to the pdf-document attached. The number group at the end of the filename (shonw on each page) shows the actual firmware and allows the distinction of the switches.
Kind regards
- HopchenNov 27, 2017Prodigy
Hi MarkusKern
Thanks for the files. I do not see anything really alarming in these TS files. No crash-dumps either. I suggest you get hold of support - let them take a deeper look. They can setup logging to monitor the system, to see what is going on.
Login to my.netgear.com and register your devices (if they aren't already) and raise a ticked that way.
Cheers
- Jan 17, 2024Anonymous
