John1414
Sep 22, 2016Aspirant
Switch getting error on Uplink port
Hi Guys, when I look at port status im getting a lot of errors on packets received with errors also collision frame on my unlink port. What's casuing this issue Also I would like to ...
- Sep 26, 2016
Hi John1414,
I suggest to perform the factory reset after each upgrade to have the switch start fresh with the new firmware as well as to check if it boots up fine after updating the firmware.
DaneA
NETGEAR Community Team
John1414
Sep 25, 2016Aspirant
Hi Dane,
Thanks for your reponse I have one question regarding the upgrade do I need restore factory default after each upgrade or shoud I do it once im on the latest firmware ?
Regards
Adress
DaneA
Sep 26, 2016NETGEAR Employee Retired
Hi John1414,
DaneA
