tamtieu1416's avatar
tamtieu1416
Follower
Jan 13, 2025
Switch Netgear M4350-16V4C 16-Port 25G SFP28 Managed AV Network Switch
Hi,
I have a question about switch M4350-16V4C 25G SFP28 Managed AV Network Switch . If I install AXM765 10G SFP+ to RJ45 Transceiver into this switch, Module has compatible this switch ? And bandwidth 10Gbps ?
If This module not compatible, can you advise other module ?
My computer has 10Gbps Rj45 port.
Can you advise this issue.
Thanks,
Tam Tieu
1 Reply
  • LaurentMa's avatar
    LaurentMa
    NETGEAR Expert
    Hi tamtieu1416 ,
    Thank you for considering NETGEAR M4350.
    Yes, please use the NETGEAR AXM765v2 10GBASE-T SFP+ Transceiver in any of the SFP28 ports, but pay attention to your procurement - it needs to be a legacy NETGEAR module, not counterfeit nor third-party (copper is tricky). The ordering SKU number for AXM765v2 is AXM765-20000S.
    You can refer to the M4350 datasheet: https://www.downloads.netgear.com/files/GDC/M4350/M4350_Datasheet.pdf
    Thank you,
    Laurent
ProSupport for Business
