pmotley
Jun 19, 2019Follower
Switch stack port to ethernet on FSM7328S switch?
Anybody know how to switch port 27 (preconfigured for stack) to an ethernet port? Thanks
schumaku
Jun 19, 2019Guru - Experienced User
To disable a port’s stacking mode and change it into regular gigabit Ethernet port, do the following commands (using port 27 as an example):
(FSM7328S ) #config
(FSM7328S Config ) #stack
(FSM7328S Config-stack ) #stack-port 1/0/27 ethernet
msi
Jun 20, 2019Luminary
Based on my experience with current and older models (i.e. GSM7328FS, that ran 8.0.x, yours goes up to 7.x): After changing the mode of the port, check the output of "show stack-port". Many Netgear stackable switches require a reboot in order to switch such ports between stack and ethernet mode.
