aescher
Jun 10, 2016Follower
Switch with PoE based on time table
Dear all I am looking for a Switch that allows PoE based on timetable (e.g. switch off at night). Any recommendations? I need in total 16 Ports, thereoff 4 should be PoE equipped. Regards and t...
JohnRo
Jun 10, 2016NETGEAR Employee Retired
Hello aescher,
Welcome to the community!
As of the moment, we do not have a PoE switch that has a PoE timetable settings or PoE scheduling. What we have right now on our Smart Switch series with PoE are the following features:
PoE Port Configuration:
- Admin mode
- Priority Level
- Class
- Output Voltage, Current, and Power
- Power Limit
- Status
Such features are available here (see page 46-48). You may also want to see this model.
I hope this helps.
Thanks,
