aescher
Jun 10, 2016Follower
Switch with PoE based on time table
Dear all I am looking for a Switch that allows PoE based on timetable (e.g. switch off at night). Any recommendations? I need in total 16 Ports, thereoff 4 should be PoE equipped. Regards and t...
JohnRo
Jun 13, 2016NETGEAR Employee Retired
Hi aescher,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
