billgro88
Oct 28, 2024Follower
This this behavior expected? An error when configuring Multiple MAC ACLS Sets on one port
Is this expected behavior? I am currently attempting to configure MAC address ACLs on my switch. On certain ports we have multiple virtual devices that connect to a single port. Given that only 10 MAC address can be configured per ACL, I've had to create multiple ACL sets designed to cover the same port. For example lets say port 1 has 20+ virtual MAC address going through it, I have to create two ACL rules with 10 MACs each. The problem arises when I set the specific port for the ACLs in "MAC Binding Configuration". When I try to set one of the ACLs for port 1 I have no issue, however when I try to add the second ACL to port 1 its errors out and does not add the ACL to port 1. I've tried changing the sequence number of the second ACL, but it still errors out. Has anyone else had this issue, and is there a work around or something I'm doing wrong?
1 Reply
This GS748Tv5 isn't a mananged switch, much more it belongs into the Plus and Smart Switches Forum section to discuss Smart Switches (T) and Plus Switches (E), including Local and Remote Management models.
