CrustySparks
Jan 21, 2022Tutor
Trunk two M4300-12x12F Switches without stacking
I have two M430012x12F switches that I want to connect together, but I don't want to stack them. The one (Master) is in the server room and is stacked with an M430016X, the other will reside at the ...
DaneA
Feb 08, 2022NETGEAR Employee Retired
Now, when I go to connect the second M430012x12F in an MDF room, I want it to trunk to the stack but not be a member of the stack. How would I go about this configuration?
You can connect the second M430012x12F via LAG to the existing stack. Let me share these articles below as reference guide:
How do I create two Link Aggregation Groups (LAGs) using the web interface on my managed switch?
How do I create two Link Aggregation Groups (LAGs) using CLI commands on my managed switch?
DaneA
NETGEAR Community Team
- CrustySparksFeb 09, 2022Tutor
The LAG seems to meet with the same problem as trunking.
Unless there is a command to force the LAG up, it is down on one side:
Current configs on both sides:
172.16.0.12:
!System Software Version "12.0.13.8"
!System Up Time "0 days 14 hrs 30 mins 17 secs"
!Additional Packages QOS,Multicast,IPv6,IPv6 Management,Stacking,Routing
!Current SNTP Synchronized Time: SNTP Last Attempt Status Is Not Successful
vlan database
vlan 2-7,9
vlan name 2 "admin"
vlan name 3 "wifi"
vlan name 4 "stdnt"
vlan name 5 "mgmt"
vlan name 6 "voice"
vlan name 7 "cloud"
vlan name 9 "mycc"
no vlan routing 1
vlan routing 2 1
vlan routing 3 2
vlan routing 4 3
vlan routing 5 4
vlan routing 6 5
vlan routing 7 6
vlan routing 9 7
exitconfigure
stack
member 1 5
exit
no ip routing
username "admin" password
username snmpv3 authentication "admin" md5
line console
exitline telnet
exitline ssh
exitinterface 1/0/13
addport lag 1
exit
interface 1/0/14
addport lag 1
exit
interface 1/0/1
auto-negotiate
speed auto 1000 full-duplex
switchport mode trunk
switchport trunk allowed vlan 1-7,9
vlan ingressfilter
vlan participation include 2-7,9
vlan tagging 1-7,9
exitinterface lag 1
port-channel static
port-channel load-balance 3
switchport mode trunkswitchport trunk allowed vlan 1-7,9
exitinterface vlan 2
routing
exitinterface vlan 3
routing
exitinterface vlan 4
routing
ip address 192.168.0.12 255.255.255.0
exitinterface vlan 5
routing
ip address 172.16.0.12 255.255.255.0
exitinterface vlan 6
routing
exitinterface vlan 7
routing
exitinterface vlan 9
routing
exitip management vlan 5 172.16.0.12 255.255.255.0
ip management source-interface vlan 5
router rip
no enable
exit
router ospf
no enable
exit
ipv6 router ospf
no enable
exitexit
172.16.0.11:
vlan database
vlan 2-7,9
vlan name 2 "admin"
vlan name 3 "wifi"
vlan name 4 "stdnt"
vlan name 5 "mgmt"
vlan name 6 "voice"
vlan name 7 "cloud"
vlan name 9 "mycc"
no vlan routing 1
vlan routing 2 1
vlan routing 3 2
vlan routing 4 3
vlan routing 5 4
vlan routing 6 5
vlan routing 7 6
vlan routing 9 7
exitconfigure
stack
member 1 5
exit
no ip routing
line console
exitline telnet
exitline ssh
addport lag 1
exit
interface 1/0/14
addport lag 1
exit
interface 1/0/1
auto-negotiate
vlan ingressfilter
vlan tagging 1-7,9
exitinterface 1/0/24
switchport mode access
switchport access vlan 4
switchport trunk native vlan 4
exitinterface lag 1
port-channel static
routing
routing
routing
routing
ip address 172.16.0.11 255.255.255.0
routing
routing
routing
exitip management vlan 5 172.16.0.11 255.255.255.0
router rip
no enable
exit
router ospf
no enable
exit
ipv6 router ospf
no enable
exitexit
- DaneAMar 15, 2022NETGEAR Employee Retired
I apologize for the late response. :catsad:
It seems that the configuration is correct. Kindly double check the physical connections.If still the same problem, I suggest you to open a support ticket with NETGEAR Support here at anytime for further investigation.
DaneA
