KBXR
Oct 18, 2014Aspirant
"trunking" with the M4100 series
I wish to daisy chain two M4100 26G switches while maintaining support for four VLANs and inter VLAN routing. My first thought is to define a trunk port but the word "Trunk" is not in the documen...
fordem
Oct 18, 2014Mentor
Netgear uses slightly different terminology - you'll need to make configure the port you plan to use as a trunk to be a member of all four VLANs and then set the port to "tagged".
