He3456's avatar
He3456
Follower
Dec 21, 2023
two MS510TXPP switches seeing pack drops
We have 2x MS510TXPP either end of a cat6a link between 2 buildings.  We have had complaints of internet loss when using this.  We have done some basic ping testing and can see the connection between the 2 switches can drop, sometimes for over a minute.  We have 2 separate cables for this link, and we have used both and get similar results. We are using the ethernet 10GB port.  We have changed the port speed down to 5GB and still get the same results.  There doesnt seem to be a pattern to the issue.
1 Reply
  • schumaku's avatar
    schumaku
    Just curious: What shows the Cable Test? How long is the connection between these two switches?
