Alforz
Oct 22, 2024Initiate
Unable to connect switch to pfsense appliance
Hello all, hope you can help me. I have a MS510TXM switch which I'm trying to connect to a Netgate 4200 Router. My issue is I cannot get a link light on the trunk port nor the router. Here is my ...
- Oct 23, 2024
Hello Alforz
Welcome to the Netgear Community!
Link LED does indicate a successfully estblished or negotiated Ethernet physical link, independent pf the VLAN config.
Check your wiring, and the connected device config carefully.
schumaku
Oct 23, 2024Guru - Experienced User
Hello Alforz
Alforz
Oct 23, 2024Initiate
Yup, it was a bad cable.
