Akshay_gm's avatar
Akshay_gm
Follower
Jan 19, 2023
Unable to set VLAN membership for VLAN ( 1675 ), Change the port to general mode, and then try again
There is aldready a VLAN set in the switch which has all the ports assigned to it & i want to creat another VLAN. when i try to assign ports to it, It shows "Unable to set VLAN membership for VLAN ( 10 )"
and when i tryed to remove the ports from old VLAN it is showing Unable to set VLAN membership for VLAN ( 1675 ), Change the port to general mode, and then try again.
what to do
i have attached some images for refrence.
1 Reply
  • schumaku's avatar
    schumaku
    Consider to define these ports as tagged - does not make lot of sense (read: none!) having all ports on VLAN 1, 10, and 1675 defined as untagged.
ProSupport for Business
