michael1io
Apr 19, 2016Aspirant
Uplink configuration with AX742 module
Hi all, can I configure with Netgear AX742 a uplink port also or is it only for stacking? I asking because we've two Netgear switches which are not compatible for stacking regarding the used fir...
- Apr 27, 2016
Hi DaneA,
after a discussion with Netgear support, it's not possible to use it for uplinks. There is no ethernet standard implemented.
DaneA
Apr 19, 2016NETGEAR Employee Retired
Hi michael1io,
I think its possible. Make sure that the you will be using the compatible cabling type. Refer to the image below:
DaneA
NETGEAR Community Team
- michael1ioApr 27, 2016Aspirant
Hi DaneA,
- DaneAApr 27, 2016NETGEAR Employee Retired
Hi michael1io,
Thank you for sharing this relevant information here in the community. Now its clear that the AX742 module is not possible to be use for uplinks because it does not have an Ethernet standard.
Cheers,
DaneA
