michael1io's avatar
michael1io
Uplink configuration with AX742 module
Hi all,    can I configure with Netgear AX742 a uplink port also or is it only for stacking? I asking because we've two Netgear switches which are not compatible for stacking regarding the used fir...
  • michael1io's avatar
    michael1io
    Apr 27, 2016
    Hi DaneA,
    after a discussion with Netgear support, it's not possible to use it for uplinks. There is no ethernet standard implemented.
ProSupport for Business
