RichWilson
Feb 07, 2019Tutor
Use of SFP to Router
What is the technical way to use two SFP ports on this switch to connect to a Nighthawk x6 router.
I have 2 Gbics, with 2 Cat7 RJ-45 cables. Is there other/additional hardware needed?
Th...
JohnC_V
Feb 08, 2019NETGEAR Employee Retired
Hi RichWilson,
As per checking, the Nighthawk x6 router is already installed with 4 Gb LAN ports which is compatible with your M4100 switch. No need to install any additional hardware for it to work.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
