cp_chris
Jun 27, 2024Aspirant
Used M5300 blinking yellow POWER light and no CLI access
Hi, I have just bought a used M5300-52G-POE+ but after turning it on the Power LED starts off as solid yellow and then changes to flashing yellow. None of the RJ45 ports appear to work but the LE...
BrianL
Jul 01, 2024NETGEAR Moderator
Hi cp_chris,
Welcome to the Community!
Try to Erase the Current Configuration then reboot the device, if the issue persists try to activate the backup image then reboot the device again. The steps can be found here.
Kind regards,
BrianL
- cp_chrisJul 02, 2024Aspirant
Hi Brian,
Thanks for the suggestions. I actually contacted the seller and returned the device in the end. It may be broken compeltely, or maybe those steps could fix it.
Not my problem any more though
Thanks
Chris
- schumakuJul 02, 2024Guru - Experienced User
So no other options ... XMODEM the -correct- image over a serial line, but not before setting the highest baud rate available on the switch. FMI: here (read the full thread please on a similar switch model).
