USER67885's avatar
USER67885
Vlan config
Using a netgear GS724TPP to try and understand networking a little better.  boot version 1.0.0.12 Software vession 2.0.8.5   So I was able to hook this managed switch up to my Palo Alto firewal...
  • schumaku's avatar
    May 26, 2023
    The port config for g1 with two VLANs untagged (1, 10) can't work.
    For some experimentation and learning VLANs on your PA firewall, I would suggest to create  set of ports as trunks, with multiple VLANs and all tagged.
    Then add some test ports in access mode for each VLAN you want to experiment and test with. Such a test access port for VLAN X must be configured as untagged for port X, the PVID must be set to X so untagged frames re assigned to the correct.
ProSupport for Business
