ksdeepkk
Oct 27, 2022Aspirant
VLAN Configuration Not Getting Applied and Saved
Hi, We use NetGear Switch M4200 Poe Switch in our lab. Recently after Firmware Update on this system, VLAN configuration doesn't get Applied or Saved (Logged in as admin). Has any one faced this ...
DaneA
Oct 31, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Kindly try to clear the cache of the browser you are using or try to use Incognito mode in Chrome then check if the VLAN settings will get applied.
Also, you can try to use another PC or laptop to isolate the problem then check again if the VLAN settings will get applied.
Try also to reboot the M4200 switch then check if the same problem will occur.
DaneA
NETGEAR Community Team
DaneA
Nov 02, 2022NETGEAR Employee Retired
Have you tried to access the the M4200 switch via CLI? If not yet, kindly try it and check if it would respond.
You can open a support ticket with the NETGEAR Support Team here at anytime for further hardware check. Kindly state what happened and the status of your M4200 switch.
DaneA
- ksdeepkkNov 07, 2022Aspirant
Hi DaneA,
Did the configuration of VLAN through CLI and it does work. VLAN Configurations done from CLI, are visible in UI too. At least this CLI access is working, this is a good option.
But VLAN manipulations from UI doesn't take any effect. Having UI would be really useful and easy. How can this be resolved.
Awaiting your advise.
Thanks
Deepak
- DaneANov 07, 2022NETGEAR Employee Retired
I suggest you to perform a factory reset on the M4200 switch through the CLI by using the clear config command on Privileged EXEC mode then reconfigure the switch from scratch. Also, check if you will be able to access the web-GUI then configure VLANs using the web-GUI.
DaneA
