Tommott1231
Jul 06, 2022Aspirant
VLAN not working on my GS324TP
Hi, I'm quite new to VLAN so i might have made some really stupid mistakes, however i tried. Anyway, I have a setup with a Edgerouter-X and a GS324TP Switch, with ER-X being in VLAN aware mode a...
Tommott1231
Jul 07, 2022Aspirant
Thanks for the reply 🙂
Here's some photos for your reference
Port 26 is the WAN port, where it goes directly to the Edgerouter
Router is in VLAN-aware mode.
The port and PVID config.
Edgerouter settings
Still cannot get it working...
10 is abolished and is removed, however that raised another question
Since VLAN1 exists, Do i have to include it in the VID as shown above?
And if so, it is impossible to set port 26 without any other VLAN memberships
WAN port is tagged, as always, but public IP still comes when connected to port 8
Do i also have to tag the port 26(WAN) in VLAN1?
schumaku
Jul 08, 2022Guru - Experienced User
Management VLAN set to 20?
Different port plugged than the one configured?
- Tommott1231Jul 08, 2022Aspirant
There's only one edgerouter and a GS324TP so no other ports are used.
and yes, management VLAN has been set to 20
- schumakuJul 09, 2022Guru - Experienced User
And that is plugged to the port #8 configured? Not the first time this happens, count me in, too
