Tommott1231
Jul 06, 2022Aspirant
VLAN not working on my GS324TP
Hi, I'm quite new to VLAN so i might have made some really stupid mistakes, however i tried. Anyway, I have a setup with a Edgerouter-X and a GS324TP Switch, with ER-X being in VLAN aware mode a...
Tommott1231
Jul 07, 2022Aspirant
Thanks for the reply 🙂
Here's some photos for your reference
Port 26 is the WAN port, where it goes directly to the Edgerouter
Router is in VLAN-aware mode.
The port and PVID config.
Edgerouter settings
Still cannot get it working...
10 is abolished and is removed, however that raised another question
Since VLAN1 exists, Do i have to include it in the VID as shown above?
And if so, it is impossible to set port 26 without any other VLAN memberships
WAN port is tagged, as always, but public IP still comes when connected to port 8
Do i also have to tag the port 26(WAN) in VLAN1?
schumaku
Jul 09, 2022Guru - Experienced User
Put up a list which VLAN is serving what purpose.
Curious what for the network (VLAN) serving the WAN/Internet (eth0 on the router in my reading), technically either a direct link to the CPE (cable modem, fiber box, ...), or just to cover specific requirements as a dedicated VLAN, should ever pass the switch? Appears there is some odd config, mixing up the traffic for multiple VLAN somehow, to the VLAN 20. This is the only explanation why a public IP can be assigned to the switch.
- Tommott1231Jul 15, 2022Aspirant
This should be a relatively simple setup to my current configuration
by WAN IP detected, I shall clarify that mean that I saw something similar to unable to assign IP by ipconfig...
