Reto1234
Feb 28, 2023Aspirant
VLAN Problem on MS510TX Switch
Hi there Probably I'm doing something wrong. I try to to create an additional VLAN and that is not working as expected. I added a new VLAN ID 100, but as soon as I Set in the VLAN Membership the...
Reto1234
Mar 01, 2023Aspirant
I solved the problem, by assigning in the PVID Configuration to the ports the same PVID than the VLAN ID.
schumaku
Mar 01, 2023Guru - Experienced User
The poet PVID does define the VLAN untagged frames flowing into a port are assigned to. Mandatory for any kind of access port. It does not magically follow the untagged port definition.
- Reto1234Mar 06, 2023Aspirant
Thank you very much for your reply. Another question I have at the moment is, how to configure the switch, if I have a Unifi AccessPoint that needs access to both of the vlans. Any idea?
- schumakuMar 06, 2023Guru - Experienced User
Multiple VLAN on a link to an AP does indicate pure tagged VLAN for all VLANs, or a mix of an untagged and tagged connections.
- Reto1234Mar 07, 2023Aspirant
For what i've seen, as soon as I mark the Port as Tagged (for both VLANs), I cannot ping the AP anymore...
