Reto1234
Feb 28, 2023Aspirant
VLAN Problem on MS510TX Switch
Hi there Probably I'm doing something wrong. I try to to create an additional VLAN and that is not working as expected. I added a new VLAN ID 100, but as soon as I Set in the VLAN Membership the...
schumaku
Mar 01, 2023Guru - Experienced User
The poet PVID does define the VLAN untagged frames flowing into a port are assigned to. Mandatory for any kind of access port. It does not magically follow the untagged port definition.
Reto1234
Mar 06, 2023Aspirant
Thank you very much for your reply. Another question I have at the moment is, how to configure the switch, if I have a Unifi AccessPoint that needs access to both of the vlans. Any idea?
- schumakuMar 06, 2023Guru - Experienced User
Multiple VLAN on a link to an AP does indicate pure tagged VLAN for all VLANs, or a mix of an untagged and tagged connections.
- Reto1234Mar 07, 2023Aspirant
For what i've seen, as soon as I mark the Port as Tagged (for both VLANs), I cannot ping the AP anymore...
- schumakuMar 08, 2023Guru - Experienced User
The management VLAN (this is holding the IP you test by ping) remains untagged on the other vendor AP.... That's why I mentioned the "or a mix of an untagged and tagged connections".
