Drakecoldwinter
Aug 14, 2024Tutor
VLAN Routing Help
I have an old FSM726v3 switch. I would like to create 2 Vlans, one for my computers vlan1 (192.168.1.x) and another vlan200 (192.168.200.x) for a couple of crypto miners. I defined both vlans and did...
Drakecoldwinter
Aug 16, 2024Tutor
I found on internet it's a L2 switch and I need a L3 switch to be able to route between VLANs, con currently I can't setup the VLans just with the switch I'll need some extra hardware (router)
- PDAHazzardSep 04, 2024Aspirant
I have a FSM7328PS Layer 3 Managed Switch and I still can't get Inter VLAN routing working. Is there anyone who can help me out?
- ErwinLSep 05, 2024NETGEAR Moderator
Hello PDAHazzard
And welcome to the NETGEAR Community! 🙂
You may want to check the link below for Inter VLAN routing.
https://www.downloads.netgear.com/files/7000_Web_UM.pdf
Have a lovely day,
Erwin
Netgear Team- DrakecoldwinterSep 06, 2024Tutor
As my switch is a L2, I can't do routing. I have installed OpenWRT on a secondary router and will use it with the switch to define the VLans and route them with OpenWRT.
Thanks
- ErwinLSep 09, 2024NETGEAR Moderator
Hello Drakecoldwinter
Okay, keep us posted if you were able to route them with OpenWRT.
Have a lovely day,
Erwin
Netgear Team
