Drakecoldwinter
Aug 14, 2024Tutor
VLAN Routing Help
I have an old FSM726v3 switch. I would like to create 2 Vlans, one for my computers vlan1 (192.168.1.x) and another vlan200 (192.168.200.x) for a couple of crypto miners. I defined both vlans and did...
Drakecoldwinter
Aug 16, 2024Tutor
I found on internet it's a L2 switch and I need a L3 switch to be able to route between VLANs, con currently I can't setup the VLans just with the switch I'll need some extra hardware (router)
PDAHazzard
Sep 04, 2024Aspirant
I have a FSM7328PS Layer 3 Managed Switch and I still can't get Inter VLAN routing working. Is there anyone who can help me out?
- ErwinLSep 05, 2024NETGEAR Moderator
Hello PDAHazzard
And welcome to the NETGEAR Community! 🙂
You may want to check the link below for Inter VLAN routing.
https://www.downloads.netgear.com/files/7000_Web_UM.pdf
Have a lovely day,
Erwin
Netgear Team- DrakecoldwinterSep 06, 2024Tutor
As my switch is a L2, I can't do routing. I have installed OpenWRT on a secondary router and will use it with the switch to define the VLans and route them with OpenWRT.
Thanks
- PDAHazzardSep 10, 2024Aspirant
Dank Erwin!
Is there -by any change- more recent (beta-) firmware available?
I connect to the gui with a mac. The java embeds are not working, Neither are the non-java frames. Is there something to do about that?
And is there somehow something to tweak on the fans? They are blowing full force constantly what seems to be a bit overdone...
Best regards,
Martin
Apeldoorn- ErwinLSep 16, 2024NETGEAR Moderator
Hello PDAHazzard
We apologize, but the FSM726v3 switch is an older model, and firmware updates are no longer available for it. If you're having trouble accessing the UI with your Mac, could you try using a Windows machine? Regarding the fans, unfortunately, there is no option to modify their performance.
Have a lovely day,
Erwin
Netgear Team
- ErwinLSep 09, 2024NETGEAR Moderator
Hello Drakecoldwinter
Okay, keep us posted if you were able to route them with OpenWRT.
Have a lovely day,
Erwin
Netgear Team
