Drakecoldwinter
Aug 14, 2024Tutor
VLAN Routing Help
I have an old FSM726v3 switch. I would like to create 2 Vlans, one for my computers vlan1 (192.168.1.x) and another vlan200 (192.168.200.x) for a couple of crypto miners. I defined both vlans and did...
ErwinL
Sep 05, 2024NETGEAR Moderator
Hello PDAHazzard
And welcome to the NETGEAR Community! 🙂
You may want to check the link below for Inter VLAN routing.
https://www.downloads.netgear.com/files/7000_Web_UM.pdf
Have a lovely day,
Erwin
Netgear Team
Drakecoldwinter
Sep 06, 2024Tutor
As my switch is a L2, I can't do routing. I have installed OpenWRT on a secondary router and will use it with the switch to define the VLans and route them with OpenWRT.
Thanks
