mcoulter
Nov 13, 2015Follower
Vlan setup issues
We are trying to setup VLANs on two M5300 stacked switches (many more to add later but starting simple). By default we have everything on VLAN 1 and all the ports are Untagged. I'm using VLAN 7 for...
JennC
Nov 14, 2015NETGEAR Employee Retired
Hello mcoulter,
Welcome to the community!
The port where you connect the router (should be VLAN-aware router) should be tagged and the ports where you connect computers (or any VLAN-unaware LAN devices such as pass through switch, printers, etc.) should be untagged. Remember that you also need to change the PVID of the untagged ports, PVID =VLAN ID. Tagged ports' PVID need to to be changed.
